moazamali
Posted on - 07/18/2016
Adobe applications are set to be updated automatically for most of the users. But I want to check and update Adobe acrobat pro xi update manually since the computer I am using Adobe acrobat doesn’t have aninternet connection. Is there a way to install the updates manually?
How To Adobe Acrobat Pro XI Update manually?
It would be recommended to update Adobe products with the Adobe application manager as they provide and check latest updates for many security issues. But since you say that the system is not connected to the internet you can download and install by using .msp type file that is provided by the Adobe. They need to be checked regularly since they produce updates to protect your file security.
