Hey guys,
What is the best way to uninstall AOL antivirus removal? I would like to install magafee but I need to uninstall AOL antivirus removal before I can do that. Is just deleting the file in C sufficient enough?
Any help at all would be excellent. Thanks in advance.
How am I able to uninstall aol antivirus removal?
Hello Michael
In order for you to completely uninstall AOL Antivirus removal, you must go to Control Panel. At the Programs tab, select Uninstall a Program. In the list, you search for AOL Antivirus Removal tool, and then select Uninstall.
You reboot the computer, and you are good to go. After this, you can install McAfee with no problems.
I hope you found this information useful.
Randolph
