Hello experts,
How am I going to block hypertext? Give me some ways to block some hypertext around the internet or internet browser I think. Share with me your ideas about this matter for I am not an expert in researching. I need your help, thank you.
My dear,
The first place I looked was the junk mail filter, and the anti-hyper block was unchecked. This is the only place where the problem could be, you can find more information from the website link.
Hello Dear,
There are many ways to block the hypertext / hyperlinks. There are filters in each emailing system or the client with you use. Create a filter for the emails containing the hyperlinks. You can also block the specific subject. Moreover there can be some virus which might have corrupted you TCP/IP protocol stack. Try some antivirus to remove this.
Patrickk wilkins
Greetings Debora Hall,
I see you want to block hyperlink/hypertext. Sorry to say that blocking hypertext is impossible. Possible if you tweak the source code of the website but that shouldn't be necessary to do. It's not like it's a script, where you can just disable the JavaScript, or a plugin where you can just remove it on your browser. No matter how advanced browsers can be, no browser can disable a hypertext.
If the reason why you want to block hypertext because of attacks, just download a malware. I recommend you download Spyware.
I hope I helped you. Enjoy!
