How to analyze smtp logs software
I'm on an Exchange 2003 server and I would like to know how to analyze smtp logs to check email activity. I see a W3C extended log file format. Is there a software on how to analyze smtp logs?
Dear Tracey Lockey,
You have an Exchange 2003 server, and you would like to know how to analyze SMTP logs to check email activity. You see a W3C extended log file format.
Yes, there is a software to analyze SMTP logs and it is really easy to use. You can find it from this link : https://www.experts-exchange.com/questions/28415224/SMTP-log-analysis-tools-to-use.html
I think you will have no problem seeing the SMTP logs.
Thank you,
Lesliez Mark
