How to analyze wild blue signal?
How to analyze wild blue signal? I need some system or application that will probably let me check the upload and download speed of my wildblue signal internet connection. I have to be more aware on the connection speed so that I can perform my online job well.
Christine Turner.
Answered By 5 points N/A #165469
Dear user,
I have done a research on Google and have found a good application to analyze WildBlue signals. Try Channel Master 1004IFD, it is a great signal meter for WildBlue. It can also diagnose problems through its voltage readouts. You can also use WildBlue Bandwidth Monitor, it stores your bandwidth usage every hour. It shows a graph to tell you your current download and upload usage.
I hope this will help you.
Thank you.
