How and what do you Preferred CCTV Camera in Windows 7
Asked By 100 points N/A Posted on -
I do have 1 system unit Spec. Is 4Gb Ram, ASUS P5G41T-M L2X/GB/LPT,
Processor is E5700 3ghrz LGA775 2 MB Cache.
And do preferred to use then how?
Best Answer by BayEuro
Answered By 0 points N/A #82246
Hi
What model is your camera
Example: if the camera is in their checked Sony website and download the appropriate drivers
Your problem is in the drivers. I think
Regards
Answered By 10 points N/A #82248
If you are looking for a good CCTV camera then i recommend using geovision.
There are different cameras to choose from,and i recommend you use D1 solution recording that is at 704×576 resolution.
You may also try the iSpy, an open-source surveillance software for Windows.
Peter franklin
