How And When To Get A New Computer?
I am thinking to get a new computer. What is the right time? When to get a new computer?
Answered By 0 points N/A #285635
Here are the signs and situations that guide for taking a right decision at the right time.
  1. When the existing system slows down and behaves unresponsively.
  2. When there are so much virus and malware which the antivirus software cannot cure.
  3. When the latest updates don’t take place in the case of applications and Operating System.
  4. When the plug-ins don’t connect to the computer anymore.
  5. If space is running out.
  6. If the time spent on fixing the computer is more than the time spent for using.
These situations are necessary to take into an account for replacing the old one with a new computer. It is always better to replace PCs with laptops as they are more advanced and are comfortable for this generation.
