How to apply active directory update tool?
Hi everyone,
How to apply active directory update tool? What is the purpose and use of this new active directory update tool? Discuss and explain some points to be considered during the installation process and also the compatibility measurements to avoid future problems.
Best Answer by Lecky cruz
Answered By 0 points N/A #179534
Hello Emaily,
Active directory update tool applies to Windows Server 2003, Windows Server 2003 R2, Windows Server 2003 with SP1, Windows Server 2003 with SP2,Windows server 2008, Windows Server 2008 R2.
This service is used in server operating system environments to manage networks comprising Microsoft Windows Clients, Some of the tools are available to help how to install and manage Active Directory
Dcpromo.exe is Active Directory installation Wizard which is used to install Active Directory.
Adprep.exe is the Active Directory preparation tool which is used to prepare an existing Active Directory environment for a newer version of directory service.
ADMT Active Directory Migration Tool is used to restructure Microsoft Windows NT 4.0 or Active directory domains.
Rendom.exe and Gpfixup.exe are domain rename tools, used to rename and restructure domains and adjust groups policy setting to accommodate new structure.
Answered By 0 points N/A #179533
The Active Directory is invented to make it easier to control groups and users. But handling it can really be challenging.
Active Directory is at the essential of different organization's information systems.
In directory update, it allows a user to update or modernize its own information in the Active directory using a Self-service solution.
You can download it here: http://softwaretopic.informer.com/active-directory-user-update-tool/
For more information, go to this link: https://www.hugedomains.com/domain_profile.cfm?d=activedirectorytools&e=com
