Jamie Jamie
10 points
Posted on - 01/07/2013
Hi guys,
How to apply iPhone4 skin modern winamp? Can you give me the proper procedure on applying and changing a winamp skin for iPhone4 mobile device? This is very necessary to enjoy all the possible features that the device offers to its user.
Expecting some help, thank you.
Hey Jamie,
A) To install a Winamp skin, the first thing you need to do is find it online and download it to your PC. Once downloaded, double click on it and click YES when it notifies you: “Are you sure you want to install Winamp skin”.
The skin should now be automatically installed.
If the skin has no already been changed once you open Winamp; right-click on the current skin and choose “Open With”. If you cannot find Winamp within the list, click on Browse and locate it.
B) To change skins, Right click and choose Options.
Go to “Choose Skin Browser”
Search the list previewing all the skins, and choose your new skin.
C) IF you don’t have Winamp already these are the steps to get it:
The first thing you need to do is install iTunes on your PC and upgrade it to the latest version possible.
Access the Application Store on your iPhone, search and install the latest version of “Winamp”.
On your iPhone again, go to the ml_ipod website and install the latest version.
Connect your iPhone with your PC and launch Winamp. You should now be able to transfer your music and playlists!!
If you have an iPhone and you love Winamp, there is an available theme that you can use and apply that will change the look of your Winamp to that of an iPhone. To try it, go to Winamp iPhone on DeviantArt created by elralfaro. This Winamp skin is based on the Apple iPhone and the very first Winamp skin he created.
This Winamp skin includes a built-in playlist powered by “playlistPlus” with modification in the equalizer plus minor fixes. This is only an iPhone skin for Winamp. Unfortunately, Winamp is still not available for iOS or Android after its development was discontinued. Though according to sources, there is plan in 2019 to port Winamp in iOS and Android, it is still unclear when it will happen.
To make this theme work on your Winamp, you need to have Winamp 5.54 or higher and Alpha Blending must be enabled. To enable Alpha Blending, in Winamp, go to “Options”, “Preferences”, “Modern Skins” then check “Enable Desktop Alpha Blending”. When you are finished, click “Close”.
