How to apply my skins winamp ufo? I just downloaded a winamp skin with a theme of unidentified flying object or UFO. I am a fan of those ufo animation wallpapers and backgrounds, that is why I did download some themes for my winamp player.
Can you help me perform a successful installation process?
If you love Winamp like me, you must have DFX Audio Enhancer. These two will bring you excellent audio quality and performance when playing music on your computer. To download the latest Winamp, go to Winamp News and download Winamp 5.666. This is the latest and last version of Winamp after the media player was discontinued.
Winamp 5.666 with Bento skin
Now, if you have a UFO themed Winamp skin, installing it is very easy. First, you need to have Winamp installed. Once you have Winamp on your computer, you have to unpack the file. Winamp themes are normally downloaded as a ZIP file (*.zip). Scan it with your antivirus first to make sure it is clean and safe.
Once you verify that the file is safe, unpack it with WinZip, WinRAR, or 7-Zip. Once unpacked, you will get either a WSZ file (*.wsz) or a WAL file (.wal). The WSZ file is for a classic Winamp skin and the WAL file is for a modern Winamp skin. Sometimes a modern skin comes in a folder with many files in it.
If you downloaded a WSZ file or a WAL file, just double-click it and select “Yes” to install it. The file is copied to “C:\Program Files (x86)\Winamp\Skins”. If you downloaded a modern skin, you need to copy the folder full of files to “C:\Program Files (x86)\Winamp\Skins” manually.
For a little bit of history, Winamp is a media player originally developed by Dmitry Boldyrev and Justin Frankel for Nullsoft, their company, for Microsoft Windows, OS X, and Android. In 1999, Nullsoft was sold to AOL for $80 million. After that, in 2014, the company was acquired by Radionomy. You can also go to the Winamp website to get more information.
To download DFX, go to DFX Audio Enhancer. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. To use these two, first, install Winamp then try some configuring with the media player if you want. Once Winamp is installed, install DFX next. And that’s it. DFX starts automatically with Winamp.
To configure DFX, start Winamp then access the panel for DFX and change some audio effects.
I’m not a tech geek. I don’t keep up with every new gadget launch. I fly a few times a year, watch many movies on my phone, and live in a small apartment where...
With 2025 just around the corner, it is time to start thinking about what tech trends will be coming our way. Tech moves at a rapid pace. Some things may pop up next year...
1....
