How are DNS server and Active Directory set up?
Can you walk me through how a DNS server and an Active Directory are set up and named? Can both have the same name, for example: abc.com?
In Windows Server 2003 or later Active Directory domain has a DNS domain name (for example, contoso.com), and every Windows Server 2003 or later based computer has a DNS name (for example, win2kserver.contoso.com). Architecturally, domains and computers are represented both as objects in Active Directory and as nodes in DNS.
Because DNS domains and Active Directory domains share identical domain names, it is easy to confuse their roles. The two namespaces, although typically sharing an identical domain structure, store different data and, therefore, manage different objects:
Thus, the Active Directory domain computer account object is in a different namespace from the DNS host record that represents the same computer in the DNS zone.
Hope this will help you.
