How are they related i1 nextel and Skype?
How are they related i1 Nextel and Skype? Can we download the Skype application to any mobile phone and can you teach me the procedure to know the compatibility measures?
Thank you
Thank you
Different mobiles have different platform and application is designed for most of the platform. Skype is available for almost all platforms. Android user can download Skype from android market and also apk file is available on the internet. You can download from following links.
Similarly iPhones user can download from iTunes.Â
Thank you.
The Nextel i1 you are referring to is actually Motorola i1 which runs on Android 1.5 Cupcake. If you are wondering if you can install Skype for Android on your Motorola i1, I don’t think that’s possible because the Skype for Android app is designed only for Android 2.0 Eclair and later.
According to the Skype community website, there has been no support provided for handsets with Android 1.5 or even 1.6 and Skype for Android will not work on these Android operating systems. To use Skype on your handset, you need to have a device that runs on Android 2.0 Eclair or higher. You can download the latest from Skype for Android.
The latest version requires Android 2.2 Froyo or higher. The Motorola i1 Smartphone runs on single core 500 MHz Freescale Zeus 2.0 ARM1136 processor with 256 MB RAM, 512 MB ROM, and 250 MB internal storage. It supports microSD and microSDHC expandable up to 32 GB. It measures 118 x 58 x 12.8 millimeters and weighs 131 grams.
The handset is waterproof, dustproof, shockproof, and temperature resistant MIL-STD-810 certified. It has a TFT capacitive touchscreen display at 320 x 480 pixels screen resolution. It is protected by Corning Gorilla Glass and has built-in light and proximity sensors.
