How is ASUS Zenbook Prime UX31A UltraBook?
I want to know about ASUS's Zenbook Prime UX31A Ultrabook.
How is its resolution? Is it keyboard special? If yes, why?
Hello Lara,
The ASUS's Zenbook Prime UX31A Ultrabook measures 0.72" and its weight is 29lbs. It is an ultra book that has been crafted artistically and it has got a delectable hairline spun metal finish which has precision-etched concentric circles.
The ultra book is not heavy and it is made using durable aluminum chassis that is a perfect choice when it comes to ultra-portability without sacrificing the appearance or performance of the ultrabook.
Its keyboard has been given a complete overhaul. The flat metal keys have been swapped for layout that is slightly rounded, and it has black buttons.
This change gives at least 12% more travel and it as well provides a typing experience that is much more comfortable as compared to the previous generation Zebooks. As for its display resolution, the viewing angles are wide, with images only being able to wash out if you tip the screen ridiculously far forward or back.
Carl
