How to attain community support degree?
I want to become a community support worker in Bangladesh, are any basic qualification needed to get community support degree?
how can I get the degree?
Dear,
I have understood your problem and I have a solution for you. This will resolve the problem completely.
I have added a link which will surely helps you to diagnose the problem. The link has a complete detail of the problem you wants to elaborate.
https://www.ufv.ca/programs/community-support-worker-certificate/
This will helps to understand why the community worker degree is necessary and how you can get it.
It is also given in the referred page that what can you done with this degree or what type of scope it has.
Hope you got the answer.
Best of luck for your future.
