How to automate mdt 2012 branding in Windows Server 2012?
I have just downloaded the Microsoft deployment tool 2012, how can I automate the MDT 2012 branding in Windows Server 2012?
Hi Annaatutor,
You can use Skip Wizard which will you automated it completely:
Go to Settings > Priority = Default
Default > Skip Wizard > yes
You can use Skip Wizard property then you must ensure that all necessary Wizard steps have answers.
You can skip the Deployment Wizard and supply the property information the in variables during the Lite – Touch deployment process.
Skip Wizard's property's can't be used as task sequence variables as they are collected after the Wizards run, during the gather script.
