I am trying to send text message automatically to another skype client. Is it possible? I would like to format the text such as italics, Bold too. I ant to use Skype is the medium to share data between two PCs. Is it possible to and and receive skype data via external scripts? Does skype allows this? Can I force this on Skype? I would like to also send the emotions in skype too.y application will receive text from the user or reads from a file,then it sends the data to other PC via Skype. Both Skype applications will be running in PCs.
How to automatically send text via Skype application?
You can talk to your friends without a video or without video calling him using Skype. Skype has a chat window where you can compose your message and send it to your friend. Using the chat window, you can have a conversation with your friend or friends without the need for video calling. If you want to use emoticons, you can insert it anywhere in your message then click Send.
To start a conversation with a friend, start Skype then click a contact. Enter your message in the chat window then send it. Aside from chatting with friends, you can also use Skype to send a file to a friend though I’m not sure about the maximum size of the files that can be sent. A user says it is easy for him to send a 75 MB file but unable to send a file with 350 MB size.
But according to Skype, you can send a file of any size. To send a file to a friend, click on the plus button then select Send Files. Browse to the location of your file then click Send. If you are using an old version, download the latest. Check out Download Skype to download the latest version.
