Hi Experts,
I am having ms powerpoint 2007 and I am making a presentation.I need to avoid slideshow maker gratis.I tried to remove it in on design tab but could not fine it exactly.So I need expert assistance.Thanks.
Matland Maut
How to avoid slideshow maker gratis?
Did you check the add-ins section in your tool menu? I think, Gratis is attached with the design menu as an Add-in or plug and you need to unload it. Go to menu Tool->Add-ins and unload Gratis from there.
I researched on different sites in Google and found that this is the problem in the old version of the software. You should download a more recent version from any site and install this on your computer then use it. I also faced this problem but after downloading the new version, problem is solved. Hope it will help you.
