Hi Experts,
I am having Verizon media manager on my desktop. But now my version media manager get crashed very often. Then I have to reinstall it again and again. So I want to avoid version media manager crashing. Can anyone tell me how to fix that bug. Thank you.
Best Regards,
Kaitlynnatasha
How to avoid verizon media manager crashing?
I hear your concern regarding this matter. Well all i can suggest is that you have to uninstall the software and install an updated version of your Verizon media manager or if doesn't work. Find and download the Verizon media manager software that is compatible to your current operating system.
Hi there user:
In order to complete successfully the installation process of Verizon Media Manager, you should have fast internet connection, to download plug-ins and other components. It’s more important than you’re thinking. Here is the PDF for the complete installation process of Verizon Media Manager. Install it smoothly this time so no more crashing. Crashing only occurs if there’s mistake in the installation process.
Thanks for asking questions here at techyv.com
