bernardyn
Posted on - 11/06/2011
Hello there sir!
I need help on how to do backup mails in outlook express.
I have never took backup in outlook express someone kindly assist as I need to take backup manually through folders,
I can see the folder in the username folder I also need to take backup for “favorites”
Kindly advise on how to go about it and also on how to restore the same.
Your views and suggestions will be of great help to me.
Thank you.
How to back-up mails in Outlook Express
Hi user
Outlook emails and other folders can be backed into a file called personnel files folder.
To back up click on File menu and click Import and Export. Select export a file and click on next.
Select personnel files folder (.pst) and click on next.
Choose the folders you want to back up and click Next. Select a destination for the file to be saved and click on finish.
This will create a personnel files folder in the chosen destination.
To restore the backed up data, again go to Import and Export under File menu and select Import from another program or file.
Now select personnel files folder(.pst) and select the destination of the back up file and click on finish.
