I have an Alcatel OT 918 and having observed what my friend went through, I wanted to able to back up my boot files. My friends machine refused to boot and this prompted me to take precaution and make up my boot files. I have no idea how to do this for an android device. Where do I start and want do I need to make this happen?
How to back up my boot files on an android phone
Happy to support you!
It is advisable to follow the given steps to try back up boot files on Android phones.
Select menu at the home screen
Settings
Accounts
Back up & reset
Tick the necessary
Go back & Google for the files
Pick the needed files
Start the back up by tapping synchronize now
More help
With Android phones, you don’t do backup of the boot files or you don’t backup the boot files because there is nothing to backup for this part. The only things you can back up on your device are your data like contacts, pictures, files, apps, and others. The boot files are not part of the backup plan because it cannot be backed up.
If your phone doesn’t start, you can always factory reset your device and it should work normally again. There are two ways to factory reset an Android phone: from within the phone or in the Settings and in Recovery Mode when the phone is not accessible like when it is stuck in the logo.
Before doing a factory reset, always back up your phone’s data to your memory card then remove the memory card and SIM card from the phone.
