How to backup dvd to hard drive Mac?
Hello experts,
How to backup DVD to hard drive mac? Mac operating system is not that easy to handle but I am on the process of getting to know it, can you give me some step by step procedure on how to make or create backup DVD to hard drive mac? I hope you can share it with me.
Thank you.
Best Answer by Emil Onoon
Answered By 0 points N/A #180259
Hi
I will help you to back up your dvd to your hard drive. First ensure that, your Mac has a dvd drive so dvds can be read. Insert the dvd into the drive. The dvd will mount on the desktop. Open it and copy all the contents to a folder in your mac. It will be copied. Otherwise, open Disk Utility or Roxio Toast and you can copy the dvd to your hard drive.
Answered By 10 points N/A #180260
MAC is a tool which can perform many tasks. You can copy using that. If you want to copy then you need to insert the DVD into the drive and make your chosen file folder. Then copy all the folders using the MAC. After that all the process will be complete and then you can do whatever you want.
