How to ban porn sites in my computer ?
Good Day!
Can someone help me how to ban porn sites in my computer because I don't want my children to watch explicit contents in the internet.
Good Day!
You can block some specific sites from the control panel and then go to internet options security tab here you can set the security level for the sites you want to set. Also you can put the website address by adding the website and it will not open from your computer.Â
Smith Thompson
Hi there,
If you are using Google or Yahoo search engines, you can turn on the safe search. There is some porn filter software. You can install one of them. You can also use a popup blocker.
If you are using Internet Explorer then select tools, select internet options, open the content tab, enable the content advisor, and from there you can block language and other things. This does not completely block porn sites, but it is a start.
Hi Lawrence,
I would like to tell you that you cannot block porn sites completely. But you can stop your computer from accessing to certain porn sites. You must change the settings on your computer.Â
Are they popup or just the sites themselves. In the tools and internet option you need to change your privacy and security on high. Also you can use popup blockers, which certain blocks some content.
You can also install a porn filtering software like NetDog on your computer, that help to block all porn websites in the background when you're surfing on the web.
Hi Lawrence,Â
You can install a porn filter software like NetDog on the computer, that help you to block all porn websites in the background when you're surfing on the internet or if you use Internet Explorer Browser go to tools then Internet options, security put the websites you know, on the restricted sites list and put your privacy on high, get a good pop-up blocker it reduces the number of porn sites you see, but it doesn't block them all, only most of them.
