I want to create a MS PowerPoint presentation which has lots of images separately placed on every slide. Adding pictures step by step will consume a lot of my time, I want to know is there any way to import pictures in PowerPoint or any software like PowerPoint batch image importer, to help me in my job.
How to batch import pictures into PowerPoint
Hi Tay,
You should have told what system are you using and what version of PowerPoint do you have. Supposing that you are using windows.
If you're using PowerPoint 2007 or 2010, just go on insert tab and click on the Photo Album. If you're using PowerPoint 2002 or 2003, just go to insert tab, click on Picture and then on New photo Album.
Thank you.
Hi Tay Lordanjab,
There is an easy way of importing many picture files on power point that will cause you less hassle picking it up one by one, first select all the images from a certain folder that you want to import to PowerPoint.
Now, if you have minimized the program, you can click and drag all of the photos and hover it on the PowerPoint but do not lift your finger yet, after you can see the window of power point, you have to drag it again on the center so that the pictures will be deployed in the place and by batch.
