Pam Lendrum
10 points
Posted on - 01/30/2013
I played advanced block puzzle on my android. I was able to play well at the levels except at level 42. I find it difficult and I can't figure it out how to arrange the blocks correctly. Is there someone here who can show me the solution with the fewest number of moves as possible? How can I beat level 42 on Advanced Block?
How to Beat Level 42 on Advance Block?
Hello Pam,
Block Puzzle is a very addicting Android game. You can spend much time on it and you even don't notice it. Well, let's go more towards your problem and solution.
 To complete level 42 of Block Puzzle, you need to arrange your blocks just as shown in this image:
I hope you will overcome level 42 now.
Dear Mr. Pam Lendrum,
To beat this level, you should begin from the right site and keep moving through to the left site.
This level is considered to be the level that tests the expert.
After you have passed this level, you will find that subsequent levels will require you to focus some more.
Hope that this was very helpful
With my best regards,
Don Muench
