How big will the iPhone 5 screen be
I am hearing rumors that the iPhone 5 will have a bigger screen. I hope this proves to be true has anyone heard anything about this.
Dear User,
The iPhone 5 is believed to come preloaded with iOS6 when released with a screen at 4 inches tall, but no larger horizontally. Tests performed by third party companies have showed that the new iPhone will have a screen that is scaled from 640×1136 resolution. Experts say that this confirms that the iPhone 5 will have a bigger screen than its predecessors.
Thank You!
It is true that iPhone 5 will be larger than previous one but it will  most probably 3.5 inches. Otherwise  someone said that iPhone screen size will have 4 inch or 4.2 inch.  So it is not sure that what will be the actual size. So you need to wait until the iPhone 5 release.Â
According to iOS6, the iPhone 5 is rumored to have a larger screen that likely will grow to a 4-inch display size, featuring a screen resolution of 640×1136 (which was discovered after testing the iOS 6 through the iOS simulator application that is featured in the iOS development tools) and resulted in a screen that has a complete 5 rows of icons.
The Apple iPhone 5 is a 4G Smartphone operating on 2G, 3G, and 4G network bands using GSM, CDMA, HSPA, EVDO, and LTE technologies. It was unveiled to the public and released on September 2012 measuring 123.8 x 58.6 x 7.6 millimeters and weighing 112 grams.
It uses nano-SIM card and has LED-backlit IPS LCD capacitive touchscreen display with 16M colors at 640 x 1136 pixels screen resolution. It supports multi-touch protected with Corning Gorilla Glass with oleophobic coating. It runs on iOS 6 upgradable to iOS 10.2 powered by Apple A6 chipset, 1.3 GHz Dual-Core Swift (ARM 7-based) processor, and PowerVR SGX 543MP3 (triple-core graphics) GPU.
microSD is not supported. It runs on 1 GB DDR2 RAM with internal storage available in 16 GB, 32 GB, and 64 GB capacities. The primary camera supports 8 megapixels with f/2.4, 33mm, LED flash, and autofocus featuring face detection, panorama, 1/3.2″ sensor size, 1.4 µm pixel size, HDR (photo), touch focus, and geo-tagging and supports 1080p video recording at 30 fps.
The secondary camera supports 1.2 megapixels with f/2.4 and 35mm and supports 720p video recording at 30 fps featuring FaceTime over Wi-Fi or Cellular and face detection. It has 3.5-millimeter jack featuring 16-bit/44.1kHz audio and active noise cancellation with dedicated mic, Wi-Fi 802.11 a/b/g/n with dual-band and hotspot support, Bluetooth 4.0 with A2DP and LE support, GPS with A-GPS and GLONASS support, and USB 2.0 reversible connector.
It doesn’t have stereo FM radio. It has built-in accelerometer, proximity, compass, and gyro sensors. The preinstalled Safari web browser supports HTML5. Java is not supported. It runs on non-removable 5.45 Wh Li-Po 1440 mAh battery with standby time up to 225 hours both on 2G and 3G. Talk time is up to 8 hours both on 2G and 3G. It is available in black/slate and white/silver colors.
