How big will the iPhone 5 sim card be
Will the iPhone 5 SIM cards be the same size as the iPhone 4. If not how will I transfer my information from one to the other.
Hello Mary,
The iPhone 5 Sim Card is a nano-SIM card, which means that it will be quite smaller than that of the iPhone 4. The SIM card will occupy less space in the Smartphone and for that matter engineers will have extra space to fit other components inside the handset, for instance integrated circuits or antennas.
The component design remains mostly unchanged, the only slight change is that it is a bit smaller. Therefore getting the SIM card out of the Smartphone will require that one uses a paper clip or a tool similar to that which can release the mechanism holding the tray in its position.
Carl
Dear User,
We don’t exactly know what would be the exact features and physical changes that would appear on iPhone 5. But there are so many rumors for this.
And it is highly possible that iPhone 5 will use a very small SIM card. And this is known as a nano SIM.
Notifications
