Hello experts,
How to block ubisoft auto update? It is very annoying in my system tray desktop for it always pop up every minute and it annoys me too much. I need your full instruction regarding this matter, I don’t want to uninstall it I just want to cancel the updates permanently. Thank you.
How to Block the Annoying Ubisoft Auto Updater?
Hi Virginia Adams,
There are a lot of Ubisoft users that is also seek some possible solutions with your concern and I think that it would be much better if you would join them in the forum. I have attached the link of the forum below:
UBISOFT Forum: Disable Ubisoft Game Updater
Hope it would help you a lot.
Without access to the internet, the ubisoft auto update will not bother you. All you have to do is to deny it internet access using windows firewall, please follow the steps below to block the program.
Click on the Start button > Go to Control Panel > Click on Security [If you are using Windows Vista or skip this step if you are a windows 7 user] > Windows Firewall > Change Settings, and click Continue if prompted for Windows Visitor Click on the Advanced tab then uncheck ubisoft auto update to deny it access to the internet.
Check the settings. If there is any updating option, stop that thing.
Another possible way may be creating a shortcut in the desktop.
Explore and create a shortcut from the file positioned in the C drive.
This will find a way around the bothersome updating process when staring the games.
Follow the instructions : Start >> type"Update" into the search box.>>Click the link to open "Windows Update.">>Click the "Change settings" link.>> Click the drop-down box under "Important Updates." Choose the option to "Never check for updates." Click "OK."
THANK YOU !!!!!
