I am looking for help to block some websites and don't give permission to the other computer users (children) to access to those websites.
How can I do this?
Is there any software make allow me to block a list of websites that I don't want others to see?
Cruz Hit
How to block certain websites??
Depending on which browser you use you have the following options.
In Internet Explorer version 5 or later go to Tools, under Internet Options go to the Privacy tab, click Sites, type in the address you want to block and click OK. Remember, only works with one link at a time.
If you’re using Firefox it’s best to use an add-on to block sites. I highly recommend BlockSite as a top choice.
In Firefox go to Tools, click Add-ons, click Get Add-ons, choose Browse Add-ons and type BlockSite in the search box.
If you’re using Google Chrome click the wrench symbol in the upper right corner, click Tools, choose Under the Hood tab click Change Proxy Settings, then Security click Restricted Sites there double click Sites and add the site you want blocked.
