Hello experts,
I am no longer using chikka messenger can you give me some way on how to block chikka messenger? So that I will not be able to see it in my computer desktop or just give me some ways to uninstall it properly if possible. A step by step process will really help me solve the issue, thanks.
amy pete
How to block chikka messenger?
Hi Benjamin,
Since you're no longer using chikka messenger, better uninstall it. Here are the step by step process of how you can uninstall chikka messenger.
Click on 'start' button at the bottom part of your screen, it has the windows logo
Click on 'control panel'
Click on 'programs and features'
Then look for chikka
Click on 'uninstall' or after clicking chikka, it would ask you if you're sure to uninstall chikka, then just click 'yes'
Wait for it to finish
You may restart your PC and chikka should be no longer on your programs
Hope this helps.
Hello Benjamin,
You can uninstall the chikka messenger in different ways. Here is the simple step by step method to uninstall the messenger:
1. First you click on the Tools menu.
2. Now you need to click on the Extension command.
3. Now choose the Chikka Messenger to uninstall it from the computer.
4. Click the OK button to uninstall it.
5. Exit and Restart the computer.
Phia_01
10 points
Hello Benjamin,
I'll provide you the easiest way to remove Chikka Messenger on your PC.
Step 1: Right click the Shortcut/Icon of Chikka Messenger and then Properties.
Step 2: Click Open File location. And then automatically a folder will open. That folder contains all the files for Chikka Messenger.
Step 3: Delete that folder and then the icon in your desktop.
And that it! Hope this would help you!
In blocking/deleting your chikka messenger,
1. Click the start menu
2. Click control panel
3. Click Programs (Uninstall a Program)
4. Click Chikka Messenger icon, Right Click then click uninstall.
Then automatically it will be deleted in your desktop.
Thank you.
