Hello friends,
How to block funny SMS picture messages? There is a mobile phone number that keeps sending some funny and annoying SMS picture messages. I just want to ask if there is some possibility to block a specific number using my iPhone 4s mobile device? I am not that good at finding the right settings, I need some assistance.
Thanks and Regards,
Kimberly Walker.
Hi Kimberly!
The first thing you can do is to install a Firewall on your memory card. A Firewall is an application that allows user to block picture message and text message. It works via blacklist. All you need to do is add the numbers you want to block.
You can also select to block calls and messages or just calls or a just messages. From that solution, you haven't received any funny SMS picture messages from your mobile.
