How to block harassing phone calls on landline as well as cellphone.
I often get which are disturbing as well as harassing. These calls are unknowns and often comes late at nights. How to block harassing phone calls?
My family members receives a lot of phone call which are also on the blacklist.I have been experiencing harassing phone calls. I want to get rid of these calls by blocking them.
Method 1- On landline.
Step 1: Call your telephone service providers and ask them to make call blocking available for you.
Step 2: Call *60. This will activate call blocking feature.
Step 3: Follow the instructions to add number to a block list.
Method 2- On cellphone.
Step 1: Go to Settings and select Calls then Incoming calls then Blocked Callers then Blacklist.
Step 2: Choose the number from your contacts to block.
Step 3: Tap OK or Block to confirm.
