avah.hannah
30 points
Posted on - 04/25/2013
HI guys,
I’m having a problem with my mac blocking Google image searches whenever I conduct a search I understand this could be a problem with google domains but i am unsure, I would like to know if there is a way that I could use to unblock these image searches using Google to go back to normal, if anyone is aware on how to do this I am using a mac and I could use your help.
How to block image searches on my Mac
Hi Avah, on the right hand side of the search bar, you will find a link named “preferences” Click and on the safe search, click “do not filter image results” Alternatively, click on “tools” located at the top right corner of your browser, and select ”internet options” click on “control panel” internet options. Home box appears to create Page Tab Types. Add https://www.google.com/?gws_rd=ssl this will in effect change all previous defaults and point all future searches to Google. Have a good one.
