How to block internet ads- Using AdBlock and AdBlock Plus.
Whenever I use my computer. I end up visiting the websites that distracts me from my work. Which are the methods and how to block internet ads?
Internet contains a lot of advertisement. Where we come across pop ups and ads that are disturbing and distracting. We can hide ads on webpages by blocking the ads or installing adblocker extensions.
Method 1- Using AdBlock.
Step 1: Select Chrome Menu (☰) button and then More tools and then Extensions.
Step 2: At the bottom of the page you will get "Get more extensions", click it.
Step 3: Find adblock plus and choose + Free and then click add.
Step 4: Select options by clicking AdBlock button.Â
Step 5: Choose "Filter Lists" option and then Customize option.
Step 6: Select "Show ads on a webpage or domain".
Step 7: While browsing, pause AdBlock.
Method 2: Using AdBlock Plus
Step 4: Choose the option of "First Run" page.
Step 5: Select Options by clicking ABP button.
Step 6: Disallow advertising.
Step 7: Add Custom filters and also sites to your whitelist.
Step 8: While browsing, pause it.
