jaycepierce
10 points
Posted on - 09/02/2012
Hi Experts,
I am having internet explorer as my browser and I want to block sites contain words abusive.I tried on internet options but could not find it.Can anyone tell me how to achieve this?I need this to keep children safe from abusive sites.Thank you.
Jaycepierce
How to block sites contain words abusive?
Hi Jaycepierce,
I understand you issue, I suggest you follow the following steps to block sites for children safe:
Go to internet explorer > internet option
Click on security tab.
inside "select a zone to view or change security setting " find and click on Restricted sites
then find below "sites" button
click and add the sites in website box.
then apply.
I hope it may help you. Thanks!
You need to follow this path to do the same thing. I am showing this in win7 however you can do the same in other OS.
Go to “control panel” and then to “internet options”.
You then need to go through “security tab” and select “restricted sites”.
Then enter the web address in the displayed window and click “add”.
Add as many sites as you want to block.
