How to block top free beastiality site ?
Hi Experts,
I am using Internet Explorer, and I want to block the top free bestiality site.
I tried in internet options, but I could not find the exact place on the browser.
Tell me step by step procedure to achieve this.
I need this to avoid children accessing that particular website.
Thank you.
Best Regards,
Desireenataliaa
Best Answer by Andrew Kurt
Answered By 5 points N/A #131466
Hello Desireenataliaa,
You can do this using the Internet Option only.
Go to the Security Tab, then select the Restricted Sites Option, Click on the Sites button.
A dialog box will appear. Write the name of the websites you want to add.
They should be blocked.
REstricted Sites Add website to the zone
These images may help.
Happy Computing.
Jack Hostler.
Answered By 0 points N/A #196723
The following method will not only block accessing unwanted sites using Internet Explorer, but also it blocks those websites in another browser like Firefox and Chrome too.
Go to
C:WINDOWSsystem32driversetc and open the hosts file using a text editor like notepad. In the hosts file, find the line 127.0.0.1 localhost
If you want to block youtube.com type 127.0.0.1 www.youtube.com under 127.0.0.1 localhost. Replace www.youtube.com with the URL of any website that you want to block.
For example say you want to block www.youtube.com and www.yahoo.com. You must type the following text in notepad after opening the hosts file;
127.0.0.1 localhost
127.0.0.1 www.yahoo.com
Now save the hosts file and reboot your computer.
Launch Internet explorer and type www.youtube.com and hit enter. If you have followed the instructions correctly, your browser should display an error message.
Although this method seems a bit difficult, it ensures that children won’t change these settings.
