How to block a website on Safari- Steps to follow.
There are some websites that are need to be block as we don't want the younger ones to visit them. How to block a website on Safari?
Safari allow us to block certain websites. It helps in preventing us from distraction and getting occupied with unusual stuff during our work time. You can also set the timings for which you want to block websites.
Method 1- Using Mac.
Step 1: Open the Terminal and then the hosts file.
Step 2: Press Enter after typing sudo pico /etc/hosts.
Step 3: By pressing Enter at the bottom of the document for creating a new line.Â
Step 4: Type 127.0.0.1 to block a website and press Enter.
Step 5: Save and exit.
Method 2- Using iOS device.
Step 1: Select General after opening the Settings app and then Restrictions.
Step 2: Click on Enable Restrictions and then Websites.
Step 3: Enter the website that you want to block.
