I need to boot my operating system as quick as possible. So need to speed up the booting. It seems to me that my pc is booting a little slow.
I want to make it fast. Someone please give me some tips to boot my operating system faster.
How to boot up the system fast?
Usually every time you visit the home of my friend always asked me one or the other thing about computers and nearly every house I no longer start my computer. I made some minor changes in preparation and behold your PC, they are surprised that the computer can start very fast indeed.
On my computer, it only takes a few seconds to start ie. I am using Windows XP Professional. I boot up some simple but effective tweaks to use my computer faster.
Now I'm sharing, I have some techniques than any other OS on a computer running XP, can be applied to use. The most common misconfiguration in computers if it never touched my BIOS, it's really floppy disk drive or cdrom / DVD is set to boot from, and then, as if these two fail, then your hard startup files on the disk appears. If we lose many seconds. And how to put a BIOS and what to change?
When you computer, then usually you can enter the F2 key in many systems, BIOS by pressing the DEL key. If you enter the BIOS, look for boot device or select the boot and install on your hard disk to look first for boot record.
It step by step description of how it is, as there is some variation, but carefully consider, you can easily find the BIOS. When booting, some basic tests that you run really fast to forget the BIOS. Many bios do not have this feature and many do. Before that my computer has this feature, ie. was. Enable fast start, but now I'm using it without. This will kick start, but yes, you will be a slight improvement.
I'm using this point and you have several blogs / sites that mention modifying Prefetcher 2 registry keys to determine the system will help. But the fact that there is a context that really helps, also I was not able to find differences. So I wrong about Windows Prefetcher is not known recommend. Learn more about it here.
Hi Michael,
Here’s some simple tip to make your PC run faster.
1. Defrag your hard disk – click start button > program > accessories > system tools > and click the disk defragmentation icon.
When the program is open, click the analyze button.
After the scan is finished it will note you if the hard drive need to defrag or does not need defragmentation. If the notes say you need to defrag then continue to the next step.
Click the defragment button and let the program do its work. It with take awhile before the defragmentation is finished.
When the program is completed, close the program, restart if needed.
2. Another way is cleaning your registry.
The registry is where windows stores information of your entire program, it will wipe out the entire junk registry that may cause your PC slow its performance.
If you don’t have a CCleaner in your PC then you can download the program in this link.
3. Remove any unused program in your system, it also consumed some RAM, also change your wallpaper instead of picture for your desktop use a plain color it's also consumed some memory.
4. Lastly upgrade your RAM or add another RAM in your PC this will surely run your PC faster.
