How to breakdown an exe file? I have to make some research about breaking down executable files but it seems I don’t understand the process. A step by step instruction will really help me to breakdown the executable files into pieces.
Regards, Kimberly Walker.
Hello Walker. There's this software that will be of help to you. Exeinfo displays general information about .exe and other files too. You don't have to install it. All you have to do is to copy the exeinfo.exe file into any folder you want and run it. You can get a copy of it here:
http://www.nirsoft.net/utils/exeinfo.html
I hope you find this information useful in your research.
Samuel
You can try the ExeInfo utility tool. This will show the information on your executables, dynamic-link libraries or DLL, ocx and more. This tool can distinguish almost all major kinds of executables. This doesn't need to be installed, you just need to run it to start using. Click the Show File Info and choose your executable file. ExeInfo will then show all the information regarding your exe file.
