How to broadcast webcam over lan?
Hello Experts,
How to broadcast webcam over LAN? Some local area network error will occur due to my experience when I tried to broadcast my webcam over LAN and it is very disappointing for I am not an expert in networking. I really need your help on how to broadcast webcam over LAN?
Thank you.
Best Answer by CORDOBA Ferrer
Answered By 60 points N/A #183537
Hi Christine,
Some individuals usually experience the same error as yours.
I do prefer to use a software but you can also have some other solutions.
You can check on here and find the best answer that you need.
You can also check this site in networking a webcam here:
Hope that it would answer your concern.
Answered By 0 points N/A #183538
Hello Yong,
It is a complicated issue but you can take help from the site given below,
http://broadcast.software.informer.com/download-broadcast-webcam-over-lan/
You can go there and take help and get support. Or
You can take the step from
http://www.talktalk.co.uk/technology/workshops/articles/stream-webcam-video-over-a-home-network.html
Thanks
Answered By 5 points N/A #183535
If you're not very confident with your networking skills you can just try this application out it's called webcam XP here the link http://www.webcamxp.com/home.aspx i think this program can do just what you need. There's a free version so you can test it out before you think getting the more advanced versions with added features which are of course not for free.
