How browser opens the blocking?
Hello experts,
How browser opens the blocking? I use my laptop for dealing some important matter and using Mozilla Firefox browser but it seems like there are some necessary websites that has been blocked by my internet connection or computer system, I am not sure what is the cause why I can’t access those websites.
Can you tell me what to do for me to fix this issue?
Thank you.
Answered By 0 points N/A #184801
Hi Good day,
Some of the sites today have pop-ups these are windows who pop ups without your permission. Sometime the Firefox has these pop-up blocker setting its set not to be able to pop up  a popup window so it blocks sites that has popup windows.
BLOCK pop-up WINDOW
This is the setting, you can go here by putting your cursor at the top of the Firefox windows browser click Firefox, then go to Tools and click the Option. Then you can see that window above. You can uncheck that block popup windows then you don't have any restrictions in going to other websites. The problem there is you have threat of virus and etc. that can infect your computer or laptop.
Thanks and I hope that helps.
