A Najam
15 points
Posted on - 09/01/2016
I want to build my own cloud server to store various files including my photos, videos, music, and movies. Also if possible it should be a private server so only I can access and have faster access on LAN. Please help me to build your own cloud server.
How To Build Your Own Cloud Server?
Answer: To build an own cloud server follow the steps.
Step 1: Download the installer from the link below.
https://owncloud.org/download/
Step 2: Upload the downloaded installer setup-owncloud.php to your hard disk of your server.
Step 3: Before you upload to change the domain and store as the below format.
This is not a link. Just a part of the instruction.
Step 4: After you have done this open your cloud from the link and the setup would load. Follow the on screen steps and your cloud will be setup.
