How To Bulk Password Reset Active Directory?
I want to bulk password reset active directory. All the users in the active directory need to reset their password for more security. How can I do so?
To reset the password for many users in the active is a very cumbersome task as you will have to do it one after the other and it will take up so much of time. But there is many software available that can help you automate the task or reduce your efforts. One of them is ADManager Plus, which enables you to reset the password for all the users from a pre-built table.
https://www.manageengine.com/products/ad-manager/active_directory_bulk_user_modification.html
Notifications
