Shirley
10 points
Posted on - 07/22/2011
Every time I burn a CD, often corrupt whereas the setting is correct.. I use disposable Nero 8x speed 10. So there is no corrupted at all how? In software Nero burn success, but when he used a file. There are problems or corrupt and cannot be copied and other problems.
Jayar31
How to burn CD so as not to be corrupted?
Hi Shirley,
I already encounter that problem after i burn a CD using NERO application software that burned a CD/DVD to make a file copy. But after I play the CD it was corrupted. I show you the step on how to burn properly the files to be executed in the CD. First thing to do is to Open the NERO application Software program in your computer, then load a CD/DVD into your CD/DVD ROM and then select a category burn a file, but before you click the Burn button, you have noticed that if the files to be burn has exceeded into the amount capacity of the CD you are about to burn on it. you should be aware of that because it will be process and be burn but the files is not properly burn into your CD, make sure you have a file that less than the CD capacity. For example, you have a CD that has a capacity 700MB then your files is more than 700MB then it will appear an error message. So therefore, the solution of your problem is allow the files burn into your CD as a copy files that has less than amount of capacity than your CD.
Hope this helps you!
JayAr
shenna22
5 points
Hi good morning I read your issue is about burning file and transfer it into CD. And you have encountered some error during you start the burning process. Must better you will used another software for burning the CD, try to fine software for cdburner and make sure your CD-Room used is rewritable.
http://download.cnet.com/ISO-Burner/3000-2646_4-10810792.html
Just go in this site to download ISO CDburner.
NOTE:
Check the capacity of the file and CD before preceding the burning process.    Â
Make sure the CD you used for burning is good.
Regards;
Shenna22
Shirley
10 points
I need pay attention for amount capacity of the CD. I simply had to appreciate you again. I am not sure what I would have implemented without these techniques shown by you over my field. Thanks for your time  Jayar31 and Shenna22
