How to burn Mac boot disc in windows 7
Hi Experts
I am using Windows 7 in my PC and have to create bootable CD for Mac. Is there any option I can do so? Please write step by step process of burning Mac boot disc in windows 7.
Hi Experts
Follow this instruction:
> Insert the Windows install CD or DVD into your Mac computer.
> Open “Disk Utility” from the Applications/Utilities folder or from the Utilities folder in the Finder’s “Go” menu.
> Select “New Image” from the top of the window
> Click on the Windows install CD or DVD.
> Select a size for the disk image, making sure it is as large as the information on the disk.
> Select “None” from the “Encryption” menu and “Read and Write” disk image from the “Format” menu. Click “Create.
> Remove the Windows install CD or DVD from your Mac by pressing the “Eject” button in the upper right-hand corner of your keyboard.
> Insert a blank CD-R or DVD-R into your Mac’s optical drive.
> Click on the Windows disk image and click on the “Burn” icon in the upper left-hand corner.
> Select “1x” as the speed and click “Burn.” Press the “Eject” key to eject the Windows ISO disk after the burn is completed.
Hope you will enjoy it.
Thanking you
Franke Mary
