How to burn in poweriso movies audio video ts?
I wonder if what is poweriso movies audio video ts? I hear that poweriso can burn videos but what is audio ts and video ts? I have poweriso installed in my PC and I don't know how to use it. Any Idea?
Best Answer by warren todd
Answered By 0 points N/A #152829
PowerIso is a DVD burner which can only deal with data dvd. For making Video DVD (what you meant by VIDEO_TS and AUDIO_TS) you have to use different software. I would suggest you some of them :
– Nero Vision Express (the easiest)
– Pinnacle Video Studio
– Free DVD Creator
Once the movie DVD created, you can choose to burn it directly with any previous listed software or use PowerIso to do.
Answered By 0 points N/A #152830
Power ISO is a good tool, which helps us opening, extracting, burning, creating, editing, compressing, encrypting, splitting and converting ISO files from CD/DVD to internal virtual drive in the system. It can process almost all CD/DVD image files including ISO and BIN files. PowerISO provides an all-in one solution.
Videos ts means video transport stream and audio ts means audio transport stream.
First you open the poweriso media player then see all the options and what exactly you want to do with it be specific. I am letting you know few important features.
What is the advantage of use direct access archive file instead of ISO image and other CD/DVD image to backup CD/DVD?
 The first and important advantage of using direct access archive file is that can reduce the size of image file. The direct access archive file is a compressed format. It compresses raw CD/DVD data with high quality compression-method. Second you can backup secret and private CD/DVD using direct access archive file. Especially, it has the advantage to transfer CD/DVD through the internet. The direct access archive file provides both the feature of password-protected for denying the access from any unauthorized user and other feature of data encryption for defeating any sniffer and intruder.
