Hello guys how can i bypass the windows 7 ram requirements i have a 256 pc in here and i want to try windows 7 with it but it keeps on telling me that i don't meet the system requirements to run windows 7 enlighten me.
Please godbless
How to bypass windows 7 ram requirements
Hi dear windows 7 is a very detailed window and need proper configuration of system requirements for windows 7 minimum requirements of Ram is 1 GBÂ DDR. You cannot install windows 7 to any PC with 256 MB of Ram or 512 MB of RAM. Mostly we can install windows 7 with the minimum Ram of 512 but it mostly occurring problem after installation it affect on your computer efficiency to reduce speed of work.
So its better to install windows 7 with minimum Ram of 1 GBÂ DDR. Or if you want to bypass windows 7 Ram Requirements Then just try to change the slot of the Ram to another Slot and then try to restart the setup of installation.
I think there is no solution to this. If you are thinking of bypassing the RAM just to install Windows 7 on your computer that only runs on a 256 MB RAM, I think it’s not possible. But you can try if you are patient enough to do a hard drive format every now and then.
Even if you are successful in installing it, it will still be almost unusable because of the slowness. I know someone here in our place who installed Windows 7 on a Pentium 4 3GHz HyperThreading enabled computer with only 512 MB RAM.
The system already met the minimum RAM requirement but the computer is very slow and will really eat a lot of your patience just by doing a simple navigation in the folders.
If you only have a 256 MB RAM installed on your CPU, you can still install Windows XP or maybe Windows Vista but not Windows 7.
You really need to add more RAM if you want to install Windows 7.
