How can Acrobat erase the dark center of scan?
What is the tool used to erase the dark center of scan in acrobat? Not the borders only how to erase the center.
Hello Alfredo,
You can edit it with Photoshop. You need to have Photoshop CS4 or higher. I am not sure if the lower versions of this software can handle these files. You may try it if it happens to know you don't have CS4 or higher.
Before you do that, here's what I recommend you to do;
Go to your Photoshop CS4 or higher. Here's what you need to do;
Now Open back your doc and Navigate to he page. Delete the current Image and Import your edited Image to that Page. (You should have a basic knowledge on how to import image for you to do this correctly).
You can now export this doc file back to PDF file if you want to. Heres what you need to do;
Review the tutorial if your having trouble with it.
Happy Editing and Converting.
