How can adobe cs6 license expired fix?
Hay everybody,
I am using adobe CS from the last 2 years. Last night I clean up my window 7 and downloaded adobe cs6. It downloaded successfully but when I run the setup I got an error message. “Your license has been expired”.
How can I fix adobe cs6 license expired. Any idea
Best Answer by Spreckelmeyer Kayla
Answered By 0 points N/A #179586
Hi Emaily,
First of all I must say that you made a good decision. Adobe CS6 is much better than CS. Though the basic concept is same but CS6 presentation is more charming than CS. I think there may be some fault in your installation. Uninstall the program from control panel. Try to run the setup again. Many times it solves the problem. Don’t forget to check your system date and time also.
Good Luck.
Answered By 0 points N/A #179587
Hello Emaily,
I hope you have bought the license from Adobe website. In case you lose your license, Adobe center will help you out in this scenario. All you have to do is contact Adobe center for the lost license key. They will check your query and soon they will provide you assistance in this matter.
Thank you.
