pinkrahman
10 points
Posted on - 11/17/2012
Archos is a great company with their great products, it is quiet easy to use it. As they are using Android and Google, so it is also very advance.
But do anyone know that how can I install yahoo messenger on Archos successfully?
How can anyone install yahoo messenger on Archos successfully?
Normally on those types of Android devices any Application you want should be in android app store. This comes integrated with the Android device.
You can search in it for specific Application. But if you are searching for another way to install manipulated application I do not think it is a good idea and it is unethical.
Since you want to install yahoo messenger on Archos, which basically runs Android, you need to install it using Google play store.
Here is the link to the yahoo messenger app on Google play store, you can use that to install it on your device.
Hope this helps!
Drianna allen
