On my computer I used a trial version of website blocker. I was in a travel and the trial period has been expired. I thought the software would not work no longer. My thinking is partially right because blocked urls are still blocked and I cannot unblock them. I can not do anything with the blocker even uninstall the software. How can completely remove website blocker that is annoying me? Please help me.
How can completely remove website blocker for computer?
Hi there,
If you are trying to open some websites and you can’t go to that site because it is being blocked I have some suggestions for you, first try replacing the http:// to https:// at the address bar of your browser, or try changing your web proxy address.
Hope it works.
Hi Thomas,
I have read your problem. It looks like your host file is infected and it has remained set to block certain websites. It sometimes happens due to the malfunctioning or some unsuccessful uninstall of some software. Try running CCleaner , MalwareBytes & Microsoft Security Essentials. It will solve the problem.
